Quick Lift Question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-30-2012, 09:59 AM Thread Starter
Quick Lift Question
I have a 2001 F250 4x4, I bought a set of used tires and wheels the same size i had BUT the offset on the wheels is different so I find they rub front and back on the front axel. Well i took the sawsall to my plastic trim and bumper ( wife called me a redneck) anyway i still rub on the back side of the wheel well. So wondering how much i can lift the front with blocks and not have to change all kinds of stuff. I really dont want to put my old wheels back on.
Adam
2006 CC SB 4x4 Amarillo Addition
Pro-comp Lift
Rear airbags cab controls
Airaid
Livewire TS with Vivians Loony
Egr Delete
58v Ficm
Blue Spring upgrade
Stroke_My_Amarillo is offline
post #2 of 7 Old 12-30-2012, 10:32 AM
99powerstroke62's Avatar
Quoted: 56 Post(s)
Easiest and the most safe would be to get a leveling kit for your truck.
It's basically just an add-a-leaf for the front end
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #3 of 7 Old 12-30-2012, 04:31 PM Thread Starter
OK thanks will look into that
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
post #4 of 7 Old 12-30-2012, 04:34 PM
I just ordered one from Top Gunz Customz, a site sponsor on here.
It can be had for $100 shipped to your door. I'll be putting mine on this weekend.
carolinaboy02powerstroke is offline
post #5 of 7 Old 12-31-2012, 06:49 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
A 2" level kit will require a adj track bar...
Have you measured to see what height you need?
Best ride quality will always be from using a V code factory spring. You can get a hanger lift in 2,3 and 4.5" which will enhance the ride quality by giving additional travel.
2" mini spring packs can be used with stock length shocks
If you want new springs and 2" and the best ride quality get X code springs will ride better than any lift spring.
As always a 2" lift needs longer shocks and requires a adj track bar or a correctly made drop bracket to correct the axle that has now shifted 1/2-3/4" per 2" of lift. Its geometry.. a science. The axle shifting will side load your spring bushings which will cause premature failure and doglegging.
CT Performance, Inc. is offline
post #6 of 7 Old 12-31-2012, 07:08 AM
I had a similar issue with my truck. I put 1in steel blocks under my front spings and they only lightly rub in the back at full lock. That's with 275/75/16s.
01 F350 dually CCLB Lifted 7in
WW Gen2
6637 w/zoodad
6pos tuner canned tunes
isspro ev2 pyro, boost, trans temp
4.5" custom stack
AIH delete
CCV mod
22.5 rims on there way
ventryjr is offline
post #7 of 7 Old 01-01-2013, 01:03 PM Thread Starter
Getting Injector cups and new glow plugs this week so will see what i can do next weekend. Thanks for all the info
Adam
Pro-comp Lift
Airaid
Egr Delete
58v Ficm
Blue Spring upgrade
