New Gears and WORSE MPG
I have a 02 7.3 and recently changed the 3.73 gears to 4.88. The truck has a 8" lift and 37" tires. There's a 4" MBRP exhaust and air raid intake and throttle body spacer. Before the gear change I was getting about 11 MPG and now I'm at 8.5 MPG. Any idea's on what the problem is since I was told it would help my MPG's.
Sent from my Milestone X2 |
4.88 for rockcrawlin, 37" tire 4.10 is all i would go. motor must be screamin at highway speeds
My goal was to bring the truck as close to stock performance as I could while keeping the 37's and then build up power from there. What should they have told me to go to for that goal.
oh how cruel hope that wasn`t a friend with that info for ya
It's what the shop reccomended that did the job. Another shop told me that I should go with 4.56's but I trusted the first shop since they had a great reputation for building rigs.
Is that hand calculated? I prob would have done 4.10 unless you tow
I'm not sure what you mean by hand calculated. As far as towing, I don't do a ton of towing but I do pull trailers on occasion.
37" tires with 4.30 gears would be about the same as stock tires with 3.73 gears. 4.88 is insane unless your towing really heavy or always off the pavement.
Thanks for that one JSchuricht. I'll look into getting those changed out for that.
