turbo wont spool until truck is up to running temp? - Ford Powerstroke Diesel Forum
Old 12-29-2012, 10:15 AM
this is my first winter with my 03 7.3 ....... i unplugged my truck this morning and started it just like any other day but when i pulled onto the road i noticed no turbo spool after about 5 min of driving the truck was up to its normal running temp and the turbo was working just fine like nothing was ever wrong? any ideas???
Old 12-29-2012, 10:33 AM
Illiana Chapter Director
Probably hearing a hissing noise too?
Old 12-29-2012, 01:07 PM
Probably the EBPV. How cold was it when this happened?
Old 12-29-2012, 02:53 PM
yea on the hissing.. also forgot to mention that the exhaust is hacked off about 2 ft passed the back of the cab so no muffler etc (not my handy work) and response to the 2nd question about 20 degrees...... what is the letters that u mentioned?
Old 12-29-2012, 02:55 PM
EBPV (Exhaust Back Pressure Valve). It's suppose to help with engine warm up. Most guys disconnect them.
Old 12-29-2012, 03:20 PM
ok so 2 questions where do i find that to disconnect it and is there anything actually wrong with my truck.... and thank you very much for the help
Old 12-29-2012, 03:24 PM
It is a normal characteristic for that engine, however you could have a bad sensor or clogged tube making it more noticeable. There is a plug on the bottom of the turbo that you can disconnect that should make it quit.
Old 12-29-2012, 03:27 PM
like a wire harness of some sort then?
Old 12-29-2012, 03:31 PM
Yeah. I think it's a 2 wire plug
Old 12-29-2012, 03:34 PM
thanks, how would i go about checking to see if the tube is clogged?
