Old 07-25-2006, 03:36 PM
kazlx kazlx is offline
Quick question...fuel capacity on 01 F250 Crew Cab?
I am trying to find out how much gas my truck can hold. I read somewhere that when you fill with diesel it foams and causes the pump to auto shut off when the tank is not really full. I was just wondering how much gas my truck can hold. The truck is a short bed.
Old 07-25-2006, 03:40 PM
super_stroke super_stroke is offline
Power Strokeaholic
38 gallons i believe. after i shuts off on me i let it sit for a second or two then slowly add more till i see at the top.
Old 07-25-2006, 04:14 PM
Banshee34 Banshee34 is offline
Thought it was 37 or so???
Whatever you do, if you aren't pumping your own fuel, make sure it's someone who knows how to property pump diesel so it doesn't spill all over the side of your rig!
Old 07-25-2006, 05:21 PM
BluegrassHaul BluegrassHaul is offline
My 2000 CC has a 26-27 Gallon tank on it. It is a short bed as well.
Old 07-25-2006, 06:23 PM
mschn99 mschn99 is offline
Tank size varies by what modle of truck and what tank it has......tough to tell you what you have for sure because of that..
Old 07-26-2006, 05:19 AM
Jon
Tournaments Won: 1
Posts: n/a
My '02 CC SB
30 gallons dry.
Old 07-26-2006, 07:22 AM
Brian Brian is offline
ive got a 38 gallon tank- can get 4 more gallons in after the auto shut off, takes time though, lots of foam to settle down.
Old 07-26-2006, 08:11 AM
I definitely don't think it's any bigger than 30 gallons, because it shuts off at like 23-24 gallons usually. The most I have put in is 28. It is just hard to get good feel for how full it is because the diesel foams up. My car takes the same amount of fuel everytime within a few tenths of a gallon.
Old 07-26-2006, 11:37 AM
01SMOKINSD 01SMOKINSD is offline
Send a message via AIM to 01SMOKINSD Send a message via Yahoo to 01SMOKINSD
I Was Under The Assumption That Any Short Bed Sd Had A 28 Gallon Tank Reguardless Of The Cab Configuration. I Know That Mine Is 28 And My Mom Has A Cc Shortbed And Hers Is 28 As Well.
Old 07-29-2006, 09:01 AM
Glenn M Glenn M is offline
29 gal for 141.8 and 156.2 WB (short box)
38 gal for 137, 158 and 172.4 WB. (long box)
http://www.ford-trucks.com/specs/200...uty_Specs2.pdf
