What extended life coolant for really cold temps? - Ford Powerstroke Diesel Forum
Old 12-27-2012, 03:05 PM
I'll need to change my coolant in about 3K miles and wanted to switch to extended life coolant because I'm tired of screwing around with additives. I may be going to Alaska for a while and could see some -50 F temps. I checked shell and chevron coolants and they have freeze points around -30 F, so it doesn't sound like they will be good enough. So what extended life coolant can keep me protected during the Alaska winters?
Old 12-28-2012, 04:53 PM
I know there are some guys on here that run their trucks in Alaska and Canadian winters. What kind of coolant are you guys using?
Old 12-28-2012, 05:29 PM
Send a message via AIM to rufushusky
Check out the link below.
https://cglapps.chevron.com/msdspds/...&docFormat=PDF
Looks like if you run 60% coolant your fine.
Old 12-28-2012, 09:03 PM
If your truck is an EARLY 1999 they say not to run ELC do to it eating injector cups or something like that.
Old 12-28-2012, 09:45 PM
Thanks. I guess I will have to put in a 60% mix. I was hoping I could be lazy and just find a 50/50 mix to dump in. Would a 60% mix lower the boiling point. I don't want to have to change the coolant every season.
I've never heard anything about not running ELC in early 99 trucks. Don't know why it would be a problem. I have a late 99 anyway.
Old 12-29-2012, 01:13 AM
The oat chemistry of an elc will eat the sealant used on the injector cups causing coolant and fuel to mix.
Old 12-29-2012, 01:57 AM
^ thats interesting...never knew that
Old 12-29-2012, 03:56 AM
I assume that doesn't apply to the 6.0 trucks because everyone says use an ELC in those.
Sent from my iPhone using AutoGuide.com Free App
Old 12-29-2012, 04:39 AM
any CAT EC-1 is fine, just need to adjust concentrations.
the no elc applies to early 99s and older. 99 and up is fine
I made my Samsung SGH-I997 send this.
If you read, you'll know not to dump in a 50/50 pre mix.
