Power steering leak - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-27-2012, 01:55 PM Thread Starter
Power steering leak
I took my 2001 7.3 in with a power steering leak.They quoted me $70 to change the pump...pump is $66 at napa. They called this morning and said I also needed a brake booster and the total with parts and labor would be $1,100!!!!! Does this sound right to everyone here? Booster is $348 from napa.
chrashd is offline
post #2 of 7 Old 12-27-2012, 02:32 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 16 Post(s)
Did they explain why specifically you need a brake booster??? Labor charges are outrageous. Anything you can do competently yourself, jump on it.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 7 Old 12-27-2012, 02:54 PM
Doesn't the brake booster work off the power steering pump? Is it possible lack of power steering fluid caused a failure on the braking system? Were you having any trouble with the brakes on the way to the shop?
Pipewrench is offline
post #4 of 7 Old 12-27-2012, 06:50 PM Thread Starter
I wasn't having a brake problem, I kept adding fluid so it never got that low. Looks like they're wanting to change everything...booster hoses and power steering pump. I checked the prices for the parts and they'll make more on the parts than labor!!!! I brought it home and I guess I'll have to do it myself.I don't really have the time, but I don't like being ripped off! I'm 66 yrs old and thought I was done doing my own work.
chrashd is offline
post #5 of 7 Old 12-27-2012, 07:01 PM
Quoted: 16 Post(s)
If you dont have a braking problem (stiff/spongy/NO brakes) I wouldnt mess with it. What are the symptoms if any? Sounds like a stealership move...
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #6 of 7 Old 12-27-2012, 07:22 PM Thread Starter
Must be a reason they wanted to change everything...age? I thought a shop would get a discount on parts. They quoted me $709 and I can get the same booster, hose and pump for-----$277.29!!? Like I said they'll make more on parts than labor!
chrashd is offline
post #7 of 7 Old 12-31-2012, 01:12 AM
Quoted: 722 Post(s)
If its a dealer then ya, that's about the right price. OEM hydroboost is about $500. Autozone $160.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Corey@CNCFAB is online now
The Following User Says Thank You to Corey@CNCFAB For This Useful Post:
73rvhauler (06-07-2014)
