Idle Question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-25-2012, 09:00 PM Thread Starter
TwoBearBill's Avatar
Idle Question
The past few mornings when I've started my truck, it idles at about 750rpm for a few minutes, then increases suddenly to around 1000rpm and will stay there until I just barely touch the accelerator or brake pedal.
It hasn't done this until just recently, when the weather has gotten cold. I know, cold is relative, but around here freezing is considered cold weather. Does that have something to do with it? Is it normal?
Thanks,
Bill
Full Time RVer
2001 F-450 7.3L Powerstroke
4-door Crew Cab Lariat
Automatic Trans with Intermediate Clutch Upgrade
Custom Aluminum Bed by Texas Stagecoach
Auxiliary Mid-Frame 60gal Fuel Tank
Traxxus Auto Fuel Transfer System
BD Pillar Digital Readout
Factory Aluminum Wheels
Rear Air Suspension w/ Kneeler
BrakeSmart Trailer Brake Controller
20,000lb Reese Fifth Wheel Hitch
Hide-away Gooseneck Ball
TwoBearBill is offline
post #2 of 5 Old 12-25-2012, 10:06 PM
JD_MILLS's Avatar
Yes its normal for them to. I believe it goes off oil, coolant and air temp.
Sent from my SCH-I500 using AutoGuide.Com Free App
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #3 of 5 Old 12-25-2012, 11:07 PM
Sgt90's Avatar
yes, its called a high idle....once the oil pressure gets high enough it kicks on....also might sound like a jet engine firing up pending the size of your tail pipe....
2003 7.3 ccSB Lariat
~155k
5" Straight Pipe
20" XD's
37" Nitto Trail Grapplers
After-market waste gate actuator
TW 6-Pos Tuner
K & N Intake
Sgt90 is offline
post #4 of 5 Old 12-26-2012, 06:05 AM
floorboy's Avatar
Winter Operation, Hard Starting, Hissing Sound Etc...
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #5 of 5 Old 12-26-2012, 04:43 PM Thread Starter
High Idle
Thanks for the replies!
Bill
Full Time RVer
