Blow by question - Ford Powerstroke Diesel Forum
Old 12-25-2012, 04:57 PM
Blow by question
so ive got this project truck.. nothing special though, just need a work truck.
The motor seems to have a lot of blow by.. serious puffage from the oil filler. anyway i was wondering what to do about it? if one was to attempt to fix this problem, whats the cheapest way to do so? Ive always heard to just get a new engine but im weary about that because ive never had much luck and it never turns out to be cheap. preciate it guys. happy holidays
Old 12-26-2012, 05:42 AM
Is is blow by or are you leaking something that is burning off by the oil filter?
Old 12-26-2012, 08:57 AM
doesnt seem to have any leaks.. at least not any severe ones. Im talking about the smoke that puffs out of the oil FILLER on top of the engine. it also blows a little blue smoke out of the tailpipe.
Old 12-26-2012, 12:15 PM
Is it a 6.0? The 7.3 dosent have a topside oil filter. The tailpipe smoke is blow by, could be coming from a couple places. Rings or valve seals are the most likely to cause blow by. You could preform a cylinder leakage test to check the rings but you would have to disassemble the heads to check the valve seals.
Old 12-26-2012, 02:28 PM
I was wondering about this too. My 7.3 doesn't appear to have that much pressure coming out from the oil spout, but there is a noticeable smoke if you take the cap off to feel the pressure. Is this normal?
Old 12-26-2012, 02:54 PM
He said FILLER, not filter.
Old 12-26-2012, 07:02 PM
oh its a 7.3.. have had my fair share of bad luck with the 6leakers haha. so now that we've cleared up all confusion. what should i do???
Old 12-26-2012, 08:45 PM
Blow-by is a mechanical problem. There is really only one way to fix it and I am sure you are aware of the way it has to be done. No easy way to get around it. How many miles are on the truck?
You may want to actually check compression before doing a rebuild though. Just so you are not wasting your time.
Old 12-26-2012, 08:47 PM
Yes, it is normal to see the oil fumes. Lay the cap upside down on the filler neck and see if it vibrates off or blows off. If it vibrates off then you should not worry, if it blows off you have excessive blow-by.
Old 12-26-2012, 11:02 PM
thanks guys, im going to have a check done on it. like i said its a work truck so if its not a serious issue ill just drive it.
