My truck won't turn over! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-23-2012, 02:27 PM Thread Starter
Potaco80's Avatar
Okay I have a 2000 7.3 powerstroke with a dp tuner, drove the truck 2 days ago ran fine nothing was wrong with it, went to start it up yesterday and it won't turn over, plugged it in over night and still nothing, changed the cam sensor and glow plug relay, and changed the oil, it's getting fuel and cracks just won't turn overr. Thoughts??
Sent from my iPhone using AutoGuide.com App
Potaco80 is offline
post #2 of 5 Old 12-23-2012, 03:50 PM
7.3HeavyHauler's Avatar
tuner or chip? actually regardless of which put it back to stock (if you have a tuner) remove the chip from the pcm then try and start it, if it starts theres your problem.
My avatar is my goal for the 7.3
7.3HeavyHauler is offline
post #3 of 5 Old 12-23-2012, 11:21 PM
Quoted: 822 Post(s)
Bad starter ground? Did you try and jump the solenoid with channel lock pliers? When u charged it up, what voltage was the meter reading before you pulled the cables?
Corey@CNCFAB is offline
post #4 of 5 Old 12-24-2012, 05:26 AM
6.0f250firstcar's Avatar
So it is cranking or it isn't?
Sent from my iPhone using AutoGuide.com Free App
Ryan
6.0f250firstcar is offline
post #5 of 5 Old 12-25-2012, 05:05 PM
LEARNING AS I GO
bck4more's Avatar
I had the same problem had it towed to ford at they said it was the ICM so replaced it and started just fine
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
