X-code front springs/track bar? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 12-23-2012, 03:31 AM Thread Starter
Quoted: 865 Post(s)
Feedback Score: 3 reviews
I just ordered X-code(2630lb) front leaf springs to level the truck out a bit better and was wondering if the factory track bar will work. Right now I have the looking 1800lb springs.
thx
Corey@CNCFAB is offline
post #2 of 15 Old 12-23-2012, 08:34 AM
DoubleDpsd's Avatar
Subscribed. An adj track bar should come stock. Its important to be able to get everything centered, including the steering wheel.
Sent from my DROIDX that obama helped me get
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #3 of 15 Old 12-23-2012, 09:16 AM
If x codes are the ones that come with the plow package then yes. I'm running them with the OE bar, but my front axle is a little shifted to the side. An adjustable track bar would be awesome to correct this, but I believe the front axle wasn't exactly centered before I did the spring swap.
copracr is offline
post #4 of 15 Old 12-23-2012, 09:18 AM
MIne aligned fine and the wheel is centered but I think the truck dog tracks going down the road. I'm not sure if it hurts anything besides putting a little tension on the front springs.
copracr is offline
post #5 of 15 Old 12-23-2012, 06:40 PM Thread Starter
Quoted: 865 Post(s)
Interesting. Of all the OEM website parts stores, none offered adjustable OEM track bars. Some did list adjustable, but they were aftermarket brands. FYI, I like the MOOG problem solver parts. They are significantly heavier duty.
post #6 of 15 Old 12-23-2012, 06:43 PM
I think he meant should- as in they should but they didn't.
copracr is offline
post #7 of 15 Old 12-23-2012, 06:48 PM Thread Starter
Quoted: 865 Post(s)
perfect flaw of the internet. Now there's an oxymoron.
post #8 of 15 Old 12-23-2012, 06:56 PM
sniper_101's Avatar
I'd definitely run an adjustable trac bar after the spring change. Binding suspension = not cool. Especially if a person plans on hanging a plow on the front.
I have a Zone adjustable trac bar that strongly get's my recommendation. Beefy unit, and only about $100. I did put poly bushings in as well as it comes with rubber.
Also may want to just double check that your shocks are long enough to run after. It'll only be a few inches higher, but just a thought. May save a headache mid-install, lol.
2000 Ford F350 XLT - Supercab Shortbox - twin stick
1988 GMC Sierra
1994 Ford Ranger
2006 KTM 525 EXC-R - steet legal supermoto/dirt bike
sniper_101 is offline
post #9 of 15 Old 12-23-2012, 07:06 PM Thread Starter
Quoted: 865 Post(s)
Well, I already ordered the MOOG bar already. I suppose if I need to modify it I will cut it and put it in the lathe, thread it and make it adjustable. Or modify one of the brackets. As for the shocks, they are the same shock due to the spring still being an OEM part. Plus its only going to be 1.5-2" difference in height if my current springs were new. Of course I do plan on replacing them a bit later anyway.
post #10 of 15 Old 12-23-2012, 08:58 PM
Yea, it kinda makes me wonder how much of the arguing and sniping is related to little misunderstandings like that.
copracr is offline
