Boost??? - Ford Powerstroke Diesel Forum
Old 10-31-2007, 04:22 AM
Boost???
I'm sure there has been plenty posts on here about this topic, but...
How many pounds of boost can the Stock 7.3 Head Gasket Configuration take? Lets say on a 2000...
Just curious...
Old 10-31-2007, 06:38 PM
Anybody???
Old 10-31-2007, 06:40 PM
Desert Shield/Storm Vet
Not sure of the exact psi but its not a common thing for headgaskits to blow on 7.3's Seems to me its good to 40 plus psi could be more.
Old 10-31-2007, 08:25 PM
John Wood Nut Swinger
stock headgasket with stock head bolts = 40psi
stock headgasket with head studs = 55psi
Fast73, you will run into rod problems before you will lift a head. hybrids and a GT38R(shut up you TN guys) have a proven 450hp. That is with 37-40psi of boost. So, with a 2K PSD, you have PMR's and they like to snap or brake when you go over 400hp.
Old 10-31-2007, 08:29 PM
What are the limits on the OBS trucks?
I m waiting on my D66, Stage II's, and 17* HPOP
There on the way!!!yikes:
Old 10-31-2007, 08:31 PM
40psi for the OBS as well. the D66 tops out at 40psi as well.
You are going to be very happy with that combo you are getting.
Old 10-31-2007, 08:35 PM
I hope so... What kind of #'s should I expect? The engine has alot of miles but runs GREAT.... Plus it is intercooled, custome tunes and of course intake , exhayst, and guages..
Old 10-31-2007, 09:20 PM
Mid 30's right to 40psi depending on the tune you are running is what I would expect.
Old 10-31-2007, 09:24 PM
What about a Hp and TQ estamite?
Old 10-31-2007, 09:34 PM
Edging 400hp on an extreme tune. That would yield about 800+ TQ.
I made 471hp with my D66 and 240cc B code injectors. Bean was pissed at me when he found out I went with B codes with his D66.
