7.3 dies going up hills
i noticed it kinda cut out going uphill and crossing ditches then if i am going up a steep hill it will just die. If you roll back down to the flat and crank on it it will finally start after a couple minutes. I changed the cps, hpop, icp and added 2 extra quarts of oil wanted to make sure there wasnt anything else to check before i pulled the motor to check the oil sump tube any help would be greatly appreciated
Anyway to check fuel pressure when experiencing the issue?
i went to check the fuel pressure and was looking around the fuel filter assembly and found the problem. the dang nut has loosened up on the IPR and was laying in the valley put it back on and it runs like a champ again!!! Thanks
Awesome! Glad she is running for you again!
