Old 07-24-2006, 11:56 AM
mrgregory mrgregory is offline
Pyro temp
2002 E350 7.3 Just put pyro on, runs at 900 pulling the flats, 1200 hard uphill. Does this sound about normal? Or is 1200 too high? thanks
Old 07-24-2006, 12:06 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
you shouldn't run it at 1200 for more than a couple seconds! Do you have open exhaust or larger exhaust and air intake?
Old 07-24-2006, 12:13 PM
It only hits 1200 for about 2 to 5 seconds, then falls back off to around 1000. All intake and exhaust are stock.
Old 07-24-2006, 12:15 PM
What would be safe for maximum sustained temp in a long uphill pull?
Old 07-24-2006, 12:27 PM
super_stroke super_stroke is offline
Power Strokeaholic
the real question is, where's the probe? post or pre turbo?
Old 07-24-2006, 12:31 PM
Pre turbo Drivers side exhaust manifold.
Old 07-24-2006, 12:43 PM
Power Strokeaholic
1500 for a second or two is o.k, but NOT for very long. 1200 is about all i would take it tonormal. check this thread. by the way, mine is post turbo and i see 700* as normal every day driving.
Old 07-26-2006, 11:47 AM
stomper2 stomper2 is offline
600-700 normal driving on mine (pre-turbo). I've only hit 1100 once climbing a hill in OD.
Old 07-30-2006, 11:12 AM
jtomasik jtomasik is offline
I have a '99 with a complete Banks aftermarket kit (exhaust, turbo, control modules). I just bought the truck and don't drive it too hard, only once in awhile getting into the throttle, and then only for short periods of time. Usually my pyro is reading about 300F, once in awhile getting to 600F. I'm sure this would change dramatically if I was hauling heavy loads. The truck's too dang fast to get the pyro temp up just by throttling it empty. It'll hit 80 in no time, and the pyro barely creeps over 600 to do that. Maybe I should put a load of sand in the bed to make things fun...
Old 07-30-2006, 11:16 AM
mschn99 mschn99 is offline
Is your probe pre or post turbo??
