airbag light and no horn - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-20-2012, 06:36 PM Thread Starter
What would cause the airbaglight to come on and horn to go out? I need to register it and it won't pass safety
early99smoker is offline
post #2 of 6 Old 12-20-2012, 06:56 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Broken clock spring
dhanna6powerstroke is offline
post #3 of 6 Old 12-20-2012, 10:50 PM
^Agreed
Sent from my iPhone using AG Free
E99F250XLTCCSB4X4T444E is offline
post #4 of 6 Old 12-22-2012, 10:24 PM Thread Starter
Is it a pain to fix or is it relatively simple?
post #5 of 6 Old 12-23-2012, 05:33 AM
Mod Newbie
Quoted: 20 Post(s)
Airbag and steering wheel have to be removed.
post #6 of 6 Old 12-23-2012, 06:53 AM
To replace clockspring:
Disconnect batteries.
Remove round plastic covers on back of steering wheel to remove the nuts holding the airbag.
Remove and unplug airbag.
Unplug connector in front of steering wheel.
Mark position of wheel against shaft with paint pen.
Remove steering wheel nut and use puller to remove wheel.
Remove lower portion of steering column (screws)
Unplug wires at ignition and remove ignition switch (insert key and turn CCW while pushing in pin, then pull out ignition)
Unplug connector under dash
Now you can pull out the clockspring.
If you replace with ford part, just put the new one in, but with the Dorman part I used, you will need to remove the black plastic part that slides over steering shaft behind the clockspring.
Hope this helps.
