Wts and cel light - Ford Powerstroke Diesel Forum
Old 12-20-2012, 08:10 AM
Wts and cel light
This morning I was getting my phone out if my pocket and I had my foot on the brake. When I more or less stood up in the seat I put quite a bit if pressure on the brake pedal and all of a sudden the wts and ses light came on for about 10 seconds. Haven't had a chance to see if it stored a code yet or not. Not too worried about it just curious why it did it???
Old 01-03-2013, 01:59 PM
Ok I just did it again. Barely touched the brakes and got a ses and wts light. Engine hiccuped for a half a second then it returned to normal. Didn't get a code last time. Everything was up to operating temp. Will check the codes again tonight.
Old 01-10-2013, 01:50 PM
Ok this is what I got for codes.
It seemed to shift into drive pretty firmly right before it.
Old 01-10-2013, 01:52 PM
All codes were cleared within the last couple weeks btw. A lot of different stuff there. Think I have a wire rubbing somewhere confusing everything???
Old 01-10-2013, 04:10 PM
Maybe around the brake pedal?
I made my Samsung SGH-I997 send this.
Old 02-14-2013, 12:23 PM
Ok checked all the wires some time ago and didn't find anything. One day it did it about 15 times but has only done it on e since then. Got this code last night.
B1483 brake circuit input failure.
Could it be the brake switch making it miss???
Old 02-14-2013, 04:35 PM
Re: Wts and cel light
I wonder if your brake lights are coming on when it misses. If so, I bet the tc is unlocking/locking making it feel like a miss
Old 02-14-2013, 04:45 PM
do you have a brake box for a trailer. reason why i ask is i had a 95psd, and the brake box went bad. every time i got on the brakes it would shut off the engine. replace box and fix it.
Old 02-14-2013, 06:44 PM
It is a definite miss, almost kills the engine. Almost always happens when idling in park.
Never thought about the brake box, yes I have one, thanks ill unhook that for a while.
Old 02-14-2013, 07:00 PM
Yea , something is shorting and backfeeding . I would unplug the brake controller and see what you have .
