Vacuum pump & intercooler connectors ?s - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-30-2007, 04:18 PM Thread Starter
Howdy guys,
1st I'd like to thank Andy for the site-great lay out and friendly. Way to go!
Truck is an early '99, actually built Dec. '98, 153K miles.
Vacuum pump? AC/heater has only been blowing out the defrost for quite some time. Is that the vac. pump and is that the small pump on passenger side with 1 electrical connection and a dual tube vac. connection?
Also, my rubber/silicone intercooler connections seem to be either leaking from loose clamps or they're shot. Do you guys replace these rubber boots or just clean up the area and tighten the clamps?
I bought this truck 5 years ago with 90K, from a Ford dealer, so I'm just getting into the maintenance stuff other than fluids/filters.
TIA
Bottom entry for update on new part #s for vax pump....
Last edited by jackpine savages; 11-02-2007 at 03:55 PM. Reason: Update on $$$ savings for you!
jackpine savages is offline
post #2 of 10 Old 10-30-2007, 04:30 PM
Desert Shield/Storm Vet
vitalidle's Avatar
The intercooler boots will have oil seepage thats normal as the crank case is vented to the intake side of the turbo. It wouldn't hurt to snug them down. I can't help on your first question. Welcome to powerstroke.org!
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 10 Old 11-01-2007, 11:12 AM Thread Starter
Howdy vital. Thanks for the welcome. I'll tighten the clamps on the boots and keep researching the vac pump, I guess. Am I looking in the wrong area here in the Forums?
post #4 of 10 Old 11-01-2007, 11:19 AM
John Wood Nut Swinger
strokin_early_99's Avatar
Pull the glove box out and check all of the vacuum connections under the dash. I found two hoses hanging loose and it caused the defrost only to work. I had to play with where to plug them in but I got it. I can't tell you much more, that was 5 years ago.
Keep Strokin'
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #5 of 10 Old 11-01-2007, 01:03 PM
brian42's Avatar
It sounds like the vacuum pump in question. It should run to maintain a specific vacuum level in the reservoir (nearby black plastic container looking thing) next to the battery. It should run periodically to maintain vacuum levels for operation. Sounds like you have a vacuum leak (ventilation defaults to defrost with no vacuum). If the pump is running then you have a leak and it can't keep up. If it's not running then you either have a bad pump or fried the pump with it trying to keep up with a leak.
Hopefully this helps a little.
DA MOOSE
'03 F-250 Lariat FX4 CC/SB (7.3L of course!)
Stuff: Pre-Pump In-Tank Mod (ITPDiesel.com), SS HPX (ITPDiesel.com), 203F Thermostat w/Billet Housing (DieselSite.com)
Fluff: Gaylord's Fiberglass Tonneau, AIH Delete (self), aFe Pro-Guard 7 Magnum Flow OEM Replacement (AutoAnything.com), Harpoon Mod (self)
"A little nonsense now and then, is relished by the wisest men." - Willie Wonka
brian42 is offline
post #6 of 10 Old 11-02-2007, 12:55 PM Thread Starter
Ok, thanks for all the replies and assist..
Dropped g-box;everything's hooked up that I could lay eyes on.
Vac Pump is not running at all; checked electrical connection and it's solid, but I can't pull the vac. line off the unit? Part #s on the pump are
8TO 003 953-10
ANd F81H ZA451-AC Hella
Fuses all good. All vac lines I can see are good with no holes. I'd go for a new pump but I can't get that one connection off. Hmmmm...at least elimination process is further along-Thanks all.
post #7 of 10 Old 11-02-2007, 04:01 PM Thread Starter
Vac pump Part #s' for $50 savings!!!
Powerstrokeshop.com
That's the 5x updated part #, from Ford dealer, I paid $148 and PSShop has it for $98. Part # was not listed at PSShop, as parts counter guy said, Ford has changed this part # 5x.
Installed new pump and still a "no go" on getting air to work at feet, and new pump doesn't seem to be working either. Change the resistor too?
Part #/description on receipt; Pump Asy 6C3Z*2A451*A
Onward to PSSHop.com to look for a new resistor...
post #8 of 10 Old 11-06-2007, 07:06 PM
rsecondchance1's Avatar
Send a message via Yahoo to rsecondchance1
Vacumn problem
I'd put money on the vacumn sending unit just right of the vacumn pump, on the fender right behind the battery ,it controls the 'Auto Hub feature, I have replaced 3 of then. the last was a updated version in 2007. Ford cost about 42.75 if your lucky. It is an OEM part. When it stops working the defrosters go to defalut mode and none of the switches will change that.
Good luck.
2000 F-350 XLT Super Chips Stage 2,DFuser 18k Mod, Wicked Wheel ,self made air intake,CCV Mod, Oil Cross over,Trans Command,Rancho 9000,2 inch front lift with 1500lb add a leaf,5000lb rear air bags,315/60/17's, Magna Flow Shorty,JVC HD39, 800 watt amp door speakers, 600 watt amp 12 inch sub,linex bed linner
13000lb Raptor 3600 RL Toy hauler, just for the pull
Play Hard,Drive Hard,Ride Hard
If not Stay Home
Powerstroke and KTM for a rush
rsecondchance1 is offline
post #9 of 10 Old 11-07-2007, 10:02 AM Thread Starter
Good luck.
Thanks secondchance, I'll eliminate that possibility next with an order through PSShop. You've replaced THREE of em?! Holy canoli.
When I asked about a resistor, that was incorrect as I was thinking of the Chilton's manual I was looking at, and the resistor for the blower motor which is in the firewall. (The blower works just fine.) All the fuses looked good-funny how when one thing goes you end up doing a check to take a closer look at EVERYthing in the truck.
On the bright side; Trucks only got 150K on her, but I plan on having her at least another 350K. So far I have a spare/rebuilt alternator and now probably a good vacuum pump that I replaced with the new one. Spares are good for the road dog's soul, eh?
post #10 of 10 Old 11-15-2007, 12:00 PM Thread Starter
Well, the vacuum solenoid wasn't the fix either. Thanks anyway to Ben at PSShop for the effort. Now, I guess try the actual blend actuator mechanism itself? Anybody have one of THESE go out? Onward...full o joy.
