Auto meter trans gauge not working.
As soon as I start my truck the trans gauge needle jumps to 250 degrees, the Max temp on the gauge. The back light on the gauge works. I've had the gauge for about a year with no problems till now. Not sure if anyone else has had a similar problem. Not sure if its the sender or gauge. The sender is going into my auto trans and has a single wire on the end. Any help would be appreciated. Thanks
I would say your sender went out, replace that go from there. Not really anything can go wrong with the gauge itself
Do you know what the replacement part number is.
should be able to locate one just about anywhere
Autometer has a couple listed on there website. I guess I can just pull the sender out and look.
thats what i would do. good luck. other wise have your autometers been good?
I would like to just swap the sender all at once. I have the ultra lite gauges. So far no problem until now. Won't now if its the sender until I replace it. Gauge lights up and dims. Just reads 250 as soon as I start the truck. Even after its been parked overnight
Installed new sender and gauge is still not working. Turn truck on and gauge reads 250.
I would check all the wiring for the gauge. If that is in order then I would presume a broken gauge.
sounds to me the wire is broken going to the sender or the gauge. Check it closely and if you can check the ohm at the gauge from a ground to the sender wire.
