Anyone have 7 or more cab lights on their 99-03?? - Ford Powerstroke Diesel Forum
Old 12-17-2012, 10:46 PM
Thinking about doin 7 evenly spaced clearance lights but cant find any right ups or good pics. Once I drill the holes there's no goin back, if anyone has done this already post up some pics please, thanks.
Old 12-18-2012, 03:46 AM
When I had my dodge I only had 5 lights but same principle could be used, I stretched out a piece of wide masking tape acrossed the roof, find the center, marked it with a sharpie, then depending on how you wanted them spaced place each light on the tape and look at it from the front, if you like where they are then mark where they are with a pencil, then measure between them (centers) and make sure they are all the same distance, then use the sharpie to mark the holes, then drill. I got a little nervous when I drilled but they came out perfect. Don't forget however to take the headliner down first so you don't run the bit through it, then all you have left is to run the wire to the headlight switch, you'll have to get a schematic or someone will chime in as to which wire it is. One day I'll have them lights myself....one day
Old 12-18-2012, 05:59 AM
I'm going to add two more lights to mine one of these days. It can't be that hard.
Sent from my iPhone using AutoGuide.com App
Old 12-18-2012, 07:14 AM
its not, the hardest part is trying to figure out what configuration you want to use:
* *** * / * * * * * / ***** < just some that I have seen
Old 12-18-2012, 07:45 AM
My 2002 truck did not come with cab lights, but I installed 7 evenly spaced across the top.
Old 12-18-2012, 08:58 PM
That looks good. Any night pictures
Old 12-18-2012, 09:54 PM
Have a friend, on his old 02 cclb, he did this to, turned out really good with the 05 mirrors. One thing he wished he would have done was go with the factory base with the aftermarket led lenses. Other than that, couldnt go wrong with 7 lights on top. He actually tried to get 9 lights on there but just couldnt work out right
Old 12-19-2012, 10:53 AM
Thanks guys, I think Ill go for it.
Old 12-19-2012, 10:57 AM
7.3 4 Ever! Nothing else!
Feedback Score: 7 reviews
I love avatar sig BTW!!! And post some pics when ur done with the cab light. I have them in stock if you need them!
