Truck struggles to start sometimes - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-17-2012, 05:49 PM Thread Starter
zrain25's Avatar
Ok I haven't been on in a long time been working on my new project (89 supra) recently my truck has been starting funny. It has good battery's, it will start up fine cold no problem I will drive it all day go to turn it on sometimes and it seems like it has dead battery's, this happens probably once a week. Then I will go home 20 min later go in the truck and if will fit over perfect.
I checked the battery terminals I don't clean them yet
What would cause it to crank over fast most of time even after sitting for days. But sometimes even with a warm engine it struggles to turn over sometimes..,,
Sent from my iPhone using AutoGuide.com App
Early 99 201,000 miles. Extra spring up front leveled, 4 in turbo back to 6 in tip, 6637, glow shift gauges, dp tuner, kicker speakers, alpine head unit and amp, kicker sub, extang tonneau, bedliner bumpers grill, flares, and rockers, 33in toyo mt, 18in xd monsters, 05 Harley lights, recon tails and line of fire, 20% tint
zrain25 is offline
post #2 of 3 Old 12-17-2012, 09:05 PM
Turbostang500's Avatar
A bad connection somewhere.
Clean your bat terminsls and every other term on the starting circuit.
this includes between the starter and bellhousing.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #3 of 3 Old 12-18-2012, 06:30 PM
jacobford's Avatar
x2 on cleaning the terminals, also check the battery cable terminals, mine had a small crack on one of the ground cables it would just randomly not start, other times it would... that solved my problem, hope it helps and good luck
E99 F250 Lariat, 12-2-97 Build Date (#299 off the line), DIY 6637, 4" Turbo-Back straight pipe w/5 1/2" tip, 17* HPOP, 120v IDM, AD Injectors, Late 99 van Turbo with billowed up-pipes, 03 interior upgrade, 08 Tailgate and taillights, Leveled on 315/75/16 Dynapro M/T's
jacobford is offline
