Diesel engine rumping - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-17-2012, 04:30 PM Thread Starter
I was wondering what may cause your diesel engine to make 2 or 3 rumping sounds when it first sarts up, and then smoothens right out. Its wierd, i go to sart it when its really cold and it starts and goes rump, rump, rump, and then idles normal. It's like I am not getting fuel when i first sart it. Any ideas, could it be the ipr sensor?
Stock!
7.3L - 03/F-350 CC Fx 4X4
4inch turbo back Flow Pro Exhaust
Edge evolution II programmer/monitor
AFE intake
stock is offline
post #2 of 6 Old 12-17-2012, 05:55 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Do you understand how heui works?
First I bet you're using 15w40 oil.
so that oil is thick cold.
When firing, injector 6 fires, using the oil and fuel in the rails. The fuel can be replenished faster than the oil since the oil is so thick. Then, injector 8 tries to fire, but has too little oil and basically misfires.
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 12-17-2012, 06:59 PM Thread Starter
I am currently using 5w40 synthetic oil. This makes me believe that maybe my IPR valve is not working right or that my oil pump is getting weak.
Stock!
AFE intake
stock is offline
post #4 of 6 Old 12-17-2012, 07:15 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Shoot, proved me wrong.
I see it's tuned though. does it do it stock?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 12-17-2012, 07:18 PM Thread Starter
Yes I have it back to stock since I had the glowplugs replaced thinking this may be the problem. I might try switching it back to tow. I have never had the programmer in any other function than tow and stock.
Stock!
AFE intake
stock is offline
post #6 of 6 Old 12-17-2012, 10:02 PM
Turbostang500's Avatar
I had the same thing but mine was 2 bad glow plugs.
it would surge hard 3 or 4 times then level off but would still have a misfire until it got a little heat in it.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
