High mileage '99 7.3 4x4 CC - Ford Powerstroke Diesel Forum
Old 12-16-2012, 03:40 PM
Looking at a '99 7.3 4x4 Crew. ~325k. Had a lot of work done on it including, glow plugs, injectors, wiring harness, tranny, transfer case solenoid, brakes, suspension, etc. No pump work and nothing done inside the engine.
He's asking $5.5k. Looks great for the year/mileage. What should I look out for?
Old 12-16-2012, 03:44 PM
Normal suspension wear ball joints etc also check the blow by other than that I love my high mileage early 99
Old 12-16-2012, 03:46 PM
One thing to also note I had to replace vc gaskets off the bat if there the org u will prob also but it's no biggie
Old 12-16-2012, 03:52 PM
I believe the ball joints, etc. have been done. By blow by, do you mean the oil filler test? This guy seems pretty honest. The only leak is the w/p gasket. I'll just replace the w/p itself too.
Old 12-16-2012, 04:02 PM
Na just get idea by pulling the oil fill cap off and seeing how much gas is coming out or u can see if u can set the cap on it and if it blows off it just gives u a ruff idea of how maintained it was. When u do it you will see what I mean other than that just the usually drive it see how it shifts also if u have a code reader u can see if it has any stored codes. But if u think the guy is pretty straight forward u should be ok
Old 12-16-2012, 04:03 PM
Price doesnt seem to far off from what ive seen in my recent search. Make an honest offer, most he'll say is no.
Old 12-16-2012, 04:05 PM
I payed 3900 for mine but it need some tlc and now a tranny but that's my fault
Old 12-17-2012, 07:30 AM
Oh, 1 other comment. Looking at the badging, I believe this is an early 99. PS badge is on the fender, not the door.
Old 12-17-2012, 07:35 AM
Yes but u can't always just go by badging check the build date it's locatd inside drivers door frame
Mine does have it on the fender and mine is a early 99 I think it's 10 of 98
Old 12-18-2012, 11:40 AM
Thanks for the help, so far!
