Auxilary Tank Install? - Ford Powerstroke Diesel Forum
Old 12-15-2012, 12:32 PM
I recently purchased a 75gal gravity fill tan. Where to tie it in to fule system? Fuel fill or vent line? My dodge had a rubber vent line so i just put a Y fitting. ut this truck has hard lines for fuel fill and vent. Any suggestions?
Old 12-15-2012, 02:44 PM
There is a kit that is a tee and has a float valve that will quit filling once full.
I made my Samsung SGH-I997 send this.
Old 12-15-2012, 02:50 PM
I seen that kit by rds. But I can't find one that says ford. It only says its for a chevy
Old 12-15-2012, 03:20 PM
I found it easy. Think it's a dodge/ford kit
Old 12-15-2012, 03:24 PM
i have an aux tank in my bed with a pump and nozzle, but eventually i'll be doing the same thing, i've seen people use the overfill tube which i believe is 3/4" hose, i've also heard that tractor supply sells the kits but dunno
Old 12-15-2012, 11:03 PM
You might have better luck searching for a transfer tank kit. An auxilary tank is used with a valve so you can select one tank or the other, a transfer tank transfers fuel to another tank.
Old 12-18-2012, 05:59 AM
I just want to tie it in to my exisisting fuel tank. Can I just put a T fitting on the vent tube?
Old 12-18-2012, 06:00 AM
you could do that but i would definately put a valve in there
Old 12-18-2012, 06:03 AM
I have a ball valve on the tank
Old 12-18-2012, 06:05 AM
you got it
