Engine accelerates on it own - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-14-2012, 04:21 PM Thread Starter
Codum's Avatar
Ok, new problem. First, last saturday morning I replaced my icp as it was leaking oil and I had a shudder at low rpm. No codes, ford checked injectors, buzz and CCT, tech said injectors were fine to start by replacing icp then ipr. I replaced the icp last Saturday, took it for a drive and shudder was gone. I also noticed oil on the top of motor so I washed it off as I have done twice a year since I bought the truck new. After washing it would not start! Well it would for a few seconds then slowly die, sometimes, sometimes it would not start at all, just crank over, no smoke no start. With out smoke no fuel, after about two hours it finely started. Now the problem, I commute 90 miles to work every day. Everyday this week once or twice each way the engine feels like it is accelerating. I let of the pedal it stops, I press the pedal again and it bucks really hard once or twice, then it runs fine the rest of the trip, no cel. Had it scanned and no codes. Anybody experience this?
2014 F250 CCSB 6.7
80 gallon fuel tank in bed
"We Farm for Ducks"
2005 Excursion Eddie Bauer 4X4 6.0
Stock 245k miles
Codum is offline
post #2 of 11 Old 12-15-2012, 07:39 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
These trucks are drive-by-wire, there's an accl pedal position sensor, maybe that's going bad?
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #3 of 11 Old 12-15-2012, 12:24 PM
Turbostang500's Avatar
Either that or I Wonder if the IPR is acting up.
Lee
2000 F250 PSD SCSB 4X4 418k miles straight pipe gauges 2" leveling kit 315/75r16's
6637 with custom intake pipe. TS Performance 6 position chip!
[/URL]
Please don't confuse my attitude with my personality.. my personality is who I am,my attitude depends on who you are...
Turbostang500 is offline
post #4 of 11 Old 12-16-2012, 06:51 AM Thread Starter
Codum's Avatar
I was thinking ipr also. Read about the throttle position sensors and from what others have described as it acting up at a certain throttle position each time, mine don't. Mine has done it a various speeds 50-70, never at idle. With the engine running I have wiggled all the wires on the motor with no changes so I don't think I have a harness or chaffed wire issue. Think I will replace the ipr and see if that fixes it.. Thanks!
2014 F250 CCSB 6.7
"We Farm for Ducks"
Stock 245k miles
Codum is offline
post #5 of 11 Old 12-28-2012, 06:13 PM Thread Starter
Codum's Avatar
Picked up a scan gauge, truck is running fine now, no codes, no issues? ICP at idle is 470 hot to 550 cold. At WOT 2850 is the highest ive seen. IPR varies from I think 15-50 depending on load. Is this normal readings?
2014 F250 CCSB 6.7
"We Farm for Ducks"
Stock 245k miles
Codum is offline
post #6 of 11 Old 12-28-2012, 06:34 PM Thread Starter
Codum's Avatar
Thanks, I have monitored the TPS with my scan gauge at it appears to be functioning normal. I will keep an eye on it.
2014 F250 CCSB 6.7
"We Farm for Ducks"
Stock 245k miles
Codum is offline
post #7 of 11 Old 01-02-2013, 05:45 PM Thread Starter
Codum's Avatar
Ok, still having the acceleration issue, also learning more about the issue. It actually cuts out, like it dies for a second. When it cuts out I notice on my scan gauge the icp drops to zero. When it accelerates the icp pressure increases own its on, I actually have to let off the throttle to slow it down. Both cases really last 2-3 seconds. Here's the really weird part, it happens at the same spot on the road. To be more clear, I noticed when I pass this cell tower? It happens every time with out fail, regardless of engine speed or engine tempeture. It all started when I replaced my icp sensor due to lack of power and oil leak at the old icp sensor. The new sensor did help out with the lack of power, but ever since I installed this new NAPA icp sensor this acceleration/cutting out has been happening. I travel the same path every day. This tower is 5 miles from my home and 80 miles from my place of work. On the way to work every morning the engine cuts out, on the way home every afternoon it accelerates when i pass this tower. I know this sounds crazy, but is is possible the tower is affecting this sensor?
2014 F250 CCSB 6.7
"We Farm for Ducks"
Stock 245k miles
Codum is offline
post #8 of 11 Old 01-03-2013, 04:39 PM Thread Starter
Codum's Avatar
No responses, yea I thought it was kinda crazy. However this morning when I passed the cell tower it cut out again, icp dropped to zero for 2-3 seconds then pressure came back. So I turned around three (3) times and same thing every time. Drove 86 miles to work with no issues, then drove home 86 miles, no issues till I pass the cell tower, same thing icp dropped to zero for couple seconds. So I pull over, unplug the icp sensor, turn around and pass the cell tower two times and no problem. I did notice on my scan gauge it did show an icp pressure, I have read the computer generates this pressure own its on when the icp is unplugged. So I pull over, plug the icp back up, turn around and pass the tower two more times, both times icp dropped to zero. No question in my mind I have a bad sensor that for some reason is being affected by this cell tower, I think it's a cell tower, my be for something else, but whatever it is, it is causing my sensor to cancel out and send bad info to the computer. Also this tower is very close to the road, it the closest I pass on my daily commute. Now if I could get Napa to give me a new one since this one is only a month old.
2014 F250 CCSB 6.7
"We Farm for Ducks"
Stock 245k miles
Codum is offline
post #9 of 11 Old 01-03-2013, 04:46 PM
7.3Lariat's Avatar
Very weird.
______________________________________________
Mike
SOLD
Mods: BD-X monitor, 6637, BTS, GT38R, Snow MPGMax, International up-pipes, Hi-Flow Outlet, 5" Diamondeye, HPx, FRx, Gearhead tunes, Tru-Cool tranny cooler, Remote Start
376HP 791ft-lbs on 10.15.11
7.3Lariat is offline
post #10 of 11 Old 01-05-2013, 04:48 PM Thread Starter
Codum's Avatar
Bought a new icp sensor from Ford, problem solved. Installed it this morning, drove by the cell tower twice and no issues. Besides this being very weird that a cell tower was causing problems with the new napa icp sensor, I learned that a bad icp sensor could cause the engine to shut down due to no icp pressure even though the hpop is good and the system had good pressure, just the sensor telling the computer the pressure was zero shuts the engine down.
2014 F250 CCSB 6.7
"We Farm for Ducks"
Stock 245k miles
Codum is offline
