rear brake lines - Ford Powerstroke Diesel Forum
Old 12-02-2012, 09:07 AM
rear brake lines
I am replacing all my rear brake lines. The main line from the front to the splitter on the axle is 1/4" line then 3/16th to each caliper. Can I use 1/4" to the calipers rather the the 3/16th or would be too large?
Old 12-02-2012, 10:26 AM
no one have any idea if I can use 1/4" instead of 3/16" after it splits to the calipers?
Old 12-02-2012, 12:11 PM
I'd stick with what was on there originally.
Old 12-02-2012, 03:28 PM
It won't make a difference if you use ¼" line or 1" line. Brake fluid doesn't compress. Since the volume of fluid transfer is minimal, the small increase if brake line diameter won't likely make a detectable performance difference.
Old 12-02-2012, 03:38 PM
That is what I was thinking. But I am asking due to the fact is is the braking system and do not want to guess.
