Needle bearing - Ford Powerstroke Diesel Forum
Old 12-01-2012, 10:45 PM
Needle bearing
Is there any easy way to check that little needle bearing the stub shaft rides on short of pulling the whole hub assembly. I think one of them is bad, as I'm hearing what sounds like the front end turning when I turn left, and a random clunk...that I can not track down. Driving me insane
I've already done one hub on this truck, pulling it off isn't a huge deal, but if I could avoid it, I will.
Other than the bearing, what will I need if I do have to replace it. If memory serves me correct, I'll also need that yellow o-ring seal that goes around the unit bearing?
Old 12-02-2012, 06:14 AM
The easy test is to simply lock the ft hubs IN. If the noise goes away, because Locked those needles aren't turning, then unlock them one at a time to see which side has the noise in it.
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old 12-02-2012, 06:21 AM
I'll give that a try. I'm guessing it's the right side, as the left is relatively new.
Old 12-02-2012, 09:10 AM
you will only need a new o-ring if you are still running the vacuum locks.
SM
