cargo light
May be stupid question but how do you turn on the cargo light. I have a 02 F350. I looked in the owners book and could not find anything other than there is 2 bulbs and what type bulb they are. No mention of how to turn them on.
Any help? |
usually the dimer wheel next to the headlight switch if you roll it all the way up it will turn the interior lights and cargo light on.
Thank you. I will have to check the bulbs in the cargo light. I tried rolling that switch and got nothing. Hope its just the bulbs.
Yea they should turn on when u open the doors/unlock doors too. most likely burnt out but be careful if u replace them, a friend if mine replaced his cause they weren't in there/burnt out and it turned out the previous owner took them out because there was something wrong with them/wiring and it killed the battery. Good luck
If you have no interior lights either, check fuse 35, its a 10a mini.
Thanks guys. Looks like I need some bulbs.
