High Idle question - Ford Powerstroke Diesel Forum
Old 11-28-2012, 06:50 AM
High Idle question
Just wondering if the high idle tune is worth getting? Does it make much difference over the factory high idle mode? I'm in MO so can have some cold mornings around 0, but typical winter temps are in the mid 20s.
Old 11-28-2012, 07:49 AM
Premium Starfish Member
Depends.
Have you done a EBPV delete? IF so, then getting a chip with a High Idle tune wouldn't be a bad idea.
Depending on your truck - The Air Intake Heater (AIH) and EPBV should be all you need (if they're working correctly)
Old 11-28-2012, 08:11 AM
The EBPV and AIH are intact and working properly.
