Could this be a bad ICP - Ford Powerstroke Diesel Forum
Old 11-28-2012, 12:17 AM
Hey guys new at this but I have a 1999 f250 7.3 6 speed has a 4" turbo back straight pipe a k&n intake I just bought it really didn't drive it befor I put and edge evo II programmer and if I rev it up when returning to idle it lopes and same if Im driving and push in clutch it does the same sometimes it's worse and somtimes you don't really notice it at all
Old 11-28-2012, 05:11 AM
Mine will do this and has no programmer but it isnt really bad. Dont know how severe yours is though. To answer your question, Yes, it could be caused by the ICP sensor. I would try disconnecting the edge first and see if it is better. If I remember right, the edge just modifies the signal from the ICP to get more fuel in the truck so it could just as easily be causing it. Also, if there is oil inside the connection of the ICP then it needs changed regardless.
Old 11-28-2012, 05:32 AM
Thanks for the reply ya it seems to do it in the stock setting to but not as bad as if the edge is on 2 or 3. I did take the connector off no oil there also I have my EBPV disconnected bc it was coming in and out of the cold mood making that hissing noise that won't hurt nothing will it also I have a turbo back 4" straight pipe its sounds normal if u rev it in neutral but under a load sounds like there's a flap in the pipe don't know if any of this would change that
Old 11-28-2012, 05:40 AM
I clearly didn't do my research on the programmer cuz after looking around on some post I get the vibe that the edge is a POS lol so thinking about keeping that to use for gauges and get the ts 6 position chip
Old 11-28-2012, 05:50 AM
I wasnt gonna mention the whole "Edge" thing! Lol. Most here dont like them.
As far as the EBPV, it is fine to unhook it. I know what you mean about the annoying hissing sound. Did you disconnect the electrical connection or the mechanical lever? If you did it at the lever, the flap could be flopping around inside there. These trucks have a "flutter" sound in the exhaust that is natural. The 4" straight pipe will amplify that a little bit!
The loping is probably just normal and is exaggerated when the edge is in use.
Those TS chips are the cats *** if you are going to get custom tunes from PHP, TW, Beans, Swamps, and some others that I am forgeting.
Old 11-28-2012, 06:04 AM
No I didn't undo the lever I disconnected the sensor on the turbo pedestal ya I had the ts in another truck I had but I bought the truck with all the mods done so I just left it alone I sold that and only lasted about 4 months and had to buy another Powerstroke haha but got this one stock so I'm doing the mods just not sure what's good and not so the ts ishoodoos one to run I don't want nothing crazy I use the truck to plow and drive back and forth to my shop just want some extra and love the look when you shift and see some smoke. Thanks for your help
Old 11-28-2012, 06:09 AM
What is "ishoodoos"? Lol
The Ts chip is kinda universal. You can buy ome of those with canned tunes on it for fairly cheao or all those companies I mentioned, also use the same chip for their custom tunes. Custom tunes seem to out weight everything but come at a price. Having the 6 speed will help. Do some research on here. There is plenty of info on chips and all the tuners.
Old 11-28-2012, 06:18 AM
I will do that thanks for your help
