4x4 maintenance checklist
With the snow and ice coming, is there a checklist I could go through to keep my 4x4 system ready to go?
Thanks! |
manual shift lever?
Electric switch, automatic transmission, manual hubs.
check those manual hubs, i can not begin to tell you how many of those i sell every winter! those lock out asy. strip the splines on the inside of the link asy.
What do I need to do to check them? Is there an zirk fittings on the 4x assembly? Transfer case filter/oil?
what year truck?
You might wanna grease your needle bearings on the interior of the front hub bearing assemblies before it's too late..... like me
![]() During Issac nasty water got into my right front hub, destroyed my needle bearings, which took out my outter shaft too..... 250 for shaft, 30 bucks for new ujoint, 350 for R&L side seals and ball joints while doing the fix,500 for a new hub assembly from momma Ford, plus rental car costs while truck is down........ gets spendy.. Lesson learned,,,, check them needle bearings once every 60k miles or after every water submersion.......... $$$$ |
99.5 f250
Thanks for the heads up, I'll start looking into the needle bearings. |
check that manual shift lever, when its cold out and you yank on that lever it snaps the aluminum casting to the transmission. If you see any hairline cracks or stress crack replace it so it dont leave you stranded, and tear apart your 4x4 hubs and check those splines. If they need to be replced replace them. Saves alot of headache of being stranded
Hmmm, all I have it an electric switch in the cab (2wd, 4low 4high) and manual locking hubs.
