swapping 2000 for 97 7.3
i am swapping out engines in a 2000 f-250 its a 7.3 i am swapping it with a 97 7.3 is there any thing special needs to be swapped besides the obvious ?
Depends on what is obvious to you. Injectors, valve cover harness, accessories, HPOP and cap off the hole from the mechanical fuel pump.
Don't forget the Super Duty turbo. I'd also put a set of bellowed up pipes on it before it goes in the truck. And maybe throw a set of intake boots at it. I'd also check the cover plate on the back that has a tendency to leak, most people mistake that to be a rear main seal leak.
