Thermostat- to run hotter or colder is the question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-15-2012, 12:12 PM Thread Starter
Hey there,
So this is something I have been thinking about for a long time I've heard a lot of good things about running a 203* and the info Dieselsite has is good information. but I have also heard people running a 180* like the one at Riffraff I will be moving to Tampa soon so its always warm and there will be a lot of city driving. Is the 203* still a good idea? Anyone who has done the 203* or 180* thermostat change your input would be much appreciated.
Mean_7.3 is offline
post #2 of 11 Old 11-15-2012, 12:35 PM
Quoted: 3 Post(s)
I asked the same question a while back, most of the replies were that international designed this engine to run at 203. I'd be interested to see what you find out though.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 11 Old 11-15-2012, 12:51 PM Thread Starter
Thats what I've heard as well the link i posted above from Dieselsite has a good bit of info and they say raising the temp will make the engine work less which will increase you MPG not a lot about .5 G to 1 G. So I'm hoping someone on here has this mod and can verify that raising the temp is a good idea especially when I'll be in city traffic with already hot temperatures outside.
Mean_7.3 is offline
post #4 of 11 Old 11-16-2012, 08:40 AM
eurotrashb5's Avatar
Also looking in to a new thermostat. 195* is the stock temp correct? Can't find a 203* at any of the local parts stores around here...
Enough with the stacks already...
06 F250 6.doh
Fox-body mustang mini stock w/ a 250ish rwhp 2.3L
99 CCSB 7.3 F250 - 4"MBRP turbo-back, 6637, Procomp wheels, 33s, Skyjacker leveling kit & rear add-a-leaf -- SOLD
03 SVT Focus -- SOLD
97 F350 EXLB Dually 7.3 -- SOLD
eurotrashb5 is offline
post #5 of 11 Old 11-16-2012, 03:13 PM
I installed the 203 degree thermostat earlier this year. Looking back, I think it's probably more hype than anything. I doubt that the 8 degree F change between the OEM and International part would make much of a difference.
If I were to do it again, I think I'd go with OEM.
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
post #6 of 11 Old 11-16-2012, 04:44 PM Thread Starter
I believe 195* is the stock temp. Dieselsite.com has them.
Mean_7.3 is offline
post #7 of 11 Old 11-16-2012, 04:49 PM Thread Starter
devil car why would you go with the OEM?
Mean_7.3 is offline
post #8 of 11 Old 11-17-2012, 09:08 AM
I only say that because the OEM is a little cheaper (especially when you factor in S&H) and can be purchased locally rather than having to wait for shipping. In all honesty, I'm not sure how much the 203* would cost if purchased directly from International rather than online.
Other than that, I think they are probably equally good.
post #9 of 11 Old 11-18-2012, 07:25 AM
Tj Krawler's Avatar
The International 203* will not work for us. Theirs is a short stem, we need a long stem thermostat for it to work properly.
I went OEM.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #10 of 11 Old 11-18-2012, 09:49 AM
I went OEM.
You are correct. I forgot that ours was different.
Tags
thermostat
