Belt flapping help - Ford Powerstroke Diesel Forum
Old 11-13-2012, 03:16 PM
Belt flapping help
Did a search and I couldn't find my particular issue. Looking for some opinions! I just replaced my water pump and serpentine belt and the new belt is flapping pretty good between the alternator and p/s pulleys. Flaps enough to make this annoying groan but only at idle. So, thinking it was the tensioner, I replaced it and it is still flapping. The belt is a gatorback and is the correct one.
So does anyone have any ideas? Idler pulley? Try a different belt? Any help would be great cuz it's highly annoying and I don't want to throw the belt.
Thanks!
Old 11-14-2012, 04:01 AM
Nobody has had this happen or any ideas?
Old 11-14-2012, 04:04 AM
Nope never heard of that. I'd try a different belt.
Sent from my iPhone using AutoGuide.com App
Old 11-14-2012, 05:04 AM
Is the belt the right length?? or not too make you sound stupid but did you route it the correct way??
Old 11-14-2012, 05:15 AM
Try a belt from dealer...
Sent from my ADR6400L using AutoGuide.Com Free App
Old 11-14-2012, 05:44 AM
Thanks for the replies! Yes it is the correct belt and it is routed properly. With the old belt on, the flapping isn't bad but it chirps really bad and it doesn't go away at higher rpms. I guess I'll try a motorcraft belt today. Is there any difference in belt length w/ cold weather package and w/o it?
Old 11-14-2012, 07:22 AM
Well Im stumped then, my belt has never done what your's is doing, when you get it solved I'd like too know what it was
Old 11-14-2012, 09:04 AM
Is it possible that the water pump pulley is out of alignment just a bit from when I put it back on?
Old 11-14-2012, 09:47 AM
If all four bolts are in it I don't see how it could be. It's a pretty tight tolerance.
Old 11-14-2012, 10:17 AM
They're all in and snug
