dually for truck pulls - Ford Powerstroke Diesel Forum
Old 11-10-2012, 12:11 PM
I have a 2000 dually and looking into getting more power in the motor, I am thinking I would like to start sled and or truck pulls with it since it is not my DD but just a toy at this time. what would I need to do to start pulling, the motor and wheels??
Old 11-10-2012, 02:57 PM
I would be concerned about the clutch, if it's stock... ditch the Hypertec for custom tunes, I recomend that one way or the other. I personally like DP Tuner (I have them in both my trucks, and will get one for the Excursion when I can talk the wife into it), but others think highly of TS style 6 pos chips with tunes buy Tony Wildman, Beans, PHP, and more... do some research, make some phone calls, and go with the one who you are most comforable with. DP's are nice, you arn't limited to just 6 tunes.
As for tires, it's going to depend on the track, an agressive all-terrain or closely-spaced tread pattern mud terrain radial seems popular at the local county fair where I work at the track for the truck pulls... so no personal experiance, but I know what I see alot of.
Micky Thompson MTZ
BF Goodrich A/T or M/T
Super Swamper Truxus STS
Toyo Open Country MT
Old 11-11-2012, 04:41 AM
I will be getting a new custom tunes. now what turbo, injectors or other things would be the best for this? also since I have never done this I can only pull with 1 wheel on the back? what size would be the best size. I have Hankooks Dynapro MT's stock size on it now.
Thanks
Old 11-11-2012, 05:06 AM
Thanks
you have to look at the rules for what class your pulling in. They have turbo size regulations.. 38r looks pretty stock though....
Old 11-11-2012, 05:26 AM
after too much reading I am thinking a s366 or modded h2e. I do not know which one to go with.
Old 11-11-2012, 03:52 PM
I don't know a lot out pulling rules, but around here you can't pull with a DRW. Not sure if they will let you to just pull one wheel off.
With the turbo, depending on rules, I would lean towards the s366 because it uses a standard mount. (T4). The h2e has a few different turbos that work with it, just not as many.
Old 11-11-2012, 07:15 PM
You do realize that to be competitive, you're going to need an easy $25,000+, right?
PontiacRoss has a 750+ HP 7.3 that he pulls with. If you want to pull and do good, you'll want to check out his set-up... and open up your wallet.
Old 11-12-2012, 03:39 AM
thanks, I was thinking of just doing it for fun. I am not looking into the 750+ pulls. just over stock or so.
and I will be looking into the area rules for summer fair truck pulls.
My stock clutch will not be good?
Old 11-12-2012, 04:18 AM
You can have a lot of fun and be somewhat competitive at the work stock level. At least if they enforce the rules that is.
Clutch clutch clutch! Can't stress that enough. I blew my stock one into about 50 pieces when pulling with stock tuning.
Sent from my iPhone using Autoguide.com App
Old 11-12-2012, 09:40 AM
WOW!! I did not think that would happen.. I will have to look into it. What should I get and where?
Also, just talked to Irate Diesel and I am now thinking s366 turbo kit and de-tuned Hybrid 250... injectors so if I want more power later the turbo and sticks are there. what do you think??
