Converting to a PTO
Not that I can afford it, but someday it would be nice to swap out my stock 4R100 trans with one that has the PTO. I run a hydraulic winch off my steering pump and it's kind of slow and under powered.
What's involved with the PTO tranny. I've never even seen a Powersmoke with a PTO. I don't even know how the output would hook up to the winch or even how it engages. |
I'm researching this myself right now as I'm currently truck shopping. From what I understand every ZF6 (the stock manual 6 speed) has a pto port. A small number of 4R100's do as well if I understand correctly.
I'm not worried about the 4R100's personally because I'm only interested in buying a manual to begin with. But yours might possibly already be setup for it, though I believe auto 4x4's never have it. From that point you'll need the pto pump to attach to it and whatever hydraulic plumbing you want to take from there. Here's a link for a reputable hydraulic pump supplier, Parker. Edit: here's a picture of the zf6, you can see the PTO port cover near the bottom with 6 bolts holding it on.
I wonder what it all looks like with the pump assembly mounted on the tranny.
Well hopefully I'll be able to show you that soon on my soon to be built work/play-rig.
Of course when I say soon I mean sometime in the next 6 months lol. Having a direct drive hydraulic pump is going to be awesome though. Here's a few things I'd like to be doing with it... -Dump bed kit -Hydraulic quick connects for whatever pto implements I might use (chipper, splitter, tiller, etc) -Hydraulic air compressor -Hydraulic motor with belt system to connect to salvaged inverter I have from a dead generator ...said motor could also be used to run a rope tow for my backcountry snowboarding addiction, or re-geared to do faster pulls for urban snowboarding/skating/wakeboarding -Hydraulic winch -Snow plow (if I end up moving to tahoe this winter) -Hydraulic jacks I still need to do a lot of research on equipment and optimal setup. What I'm trying to figure out now is if the tranny has a way to clutch the pto's output so I can turn the pump on and off or if I need to go about some other means of disconnecting it so its not constantly dragging on the engine while driving. |
any idea of what the PTO gear pattern is on the zf-6? I have a forward/reverse box I would like to install for a 10k winch.
No sorry. Could I get some more info on the box you're talking about though? Pictures would be great if you can too.
Ill get some pictures later.
All PTO's are designed to be used with the vehicle stationary. They're disconnected from the powertrain when you drive. Running them at high RPM would spell disaster. |
