battery-alternator problems
I was having a charging system problem yesterday. I stopped by autozone and had them test it. He told me the alternator was only putting out 12.9 volts. I took the alt off and took it in to have it bench tested and it passed at 14.7 volts. With the engine running I am getting 12.6v from the alt. I am getting 10.8v to the green exciter wire on the alt which seemed wrong. I then checked my batteries. Both were at 12.4v disconnected. I connected one and got 12.2v. Then I disconnected that battery and connected the other one and got 10.8v. I switched the batteries and the one battery always drops about 1.5v when connected no matter what side it is connected to. This may be a dumb question, but is it possible for a bad battery to lose 1.5v when connected? The low voltage battery was originally on the passenger side. Will 10.8v to the exciter wire cause a low output on the alt? I checked all grounds and cleaned all the terminals. Thanks in advance
Looks like you have a bad battery. With the batteries disconnected you are seeing a surface charge of 12.4v, with them connected there is a light load and the true battery voltage is showing. Try charging it overnight, if you still have 10.8v then replace both batteries.
that is correct but only one battery does this. Will low voltage to the exciter cause low output from the alt?
Sent from my PG86100 using AutoGuide.Com Free App |
The alternator is either on or off. Try this, disconnect the - on one battery, start the truck and see where the voltage is. I am guessing one battery is pulling the alternator down to 12.9v which will eventually kill the alternator. You should replace both batteries at the same time.
There was no dash lights. I took the batteries in and the one battery tested bad. Replaced both.
schemi......did replacing both batteries fix your problem ?
Yes it did. There was one bad battery. I replaced both but kept the good one for the jeep.
Thanks for the response, having a little trouble here, new alternator, one new battery, not charging at all.
The old alt. started over charging and seemingly draining batteries when not running so I replaced it. One battery was bad so I replaced that as well. I sent the alt. back, the guy tested it and says it's fine.......not quite sure what the problem is yet. |
Get your other battery tested. It could be bad dragging everything else. that is what my problem was
