next step up tire size from 265/75r16? Want bigger tires - Ford Powerstroke Diesel Forum
post #1 of 41 Old 11-06-2012, 09:57 AM Thread Starter
irishluck's Avatar
Back on this again.
Ive got 265/75r16's on my truck with a 2" leveling kit on the front and will have a 1-2" block lift on the back.
I need new tires anyways and want to get them a little bigger.
So what should I go with?
Will not be buying new rims.
2003 ford f250 turbo 7.3 rear wheel drive
4" Diamond Eye Turbo Back, MBRP 4" Delete Pipe, 5% Tint
DIY Tymar Intake, Stancor MOD, GlowShift Pod Gauges
PHP Phoenix Performance Chip, 2" Leveling kit, BDS Shocks
Xtreme Motorcycle Parts
irishluck is offline
post #2 of 41 Old 11-06-2012, 10:01 AM
Ford7three's Avatar
If you are sticking with the factory wheels go up to a 285/75R16. Will still be a little small with the small amount of lift you have but it will fill the gap a little bit better.
Ford7three is offline
post #3 of 41 Old 11-06-2012, 10:08 AM
BryceB's Avatar
Is your truck 2wd or 4wd?
this is my '01 4x4 with stock height and stock wheels on 285/75R16 tires
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #4 of 41 Old 11-06-2012, 10:20 AM Thread Starter
irishluck's Avatar
Its rear wheel drive
Id like to get some that are a little taller.
I've got 265/75r16
The 265/285 is the width, the 65/75 is the tallness isnt' it?
Id like to get like a 85r16 or 90 or something.
Is that posible?
post #5 of 41 Old 11-06-2012, 11:15 AM
BryceB's Avatar
I've got 265/75r16
Is that posible?
the first number is the tread width in mm.
the 2nd numebr is the % of the tread width that corresponds with the sidewall height
the R means it s a radial
the last number is it's wheel diameter.
you may be able to find a 265/85R15... you'll just have to look around at tire manufacture or dealer web sites. try discounttire.com or tirerack.com to see what's out there
BryceB is offline
post #6 of 41 Old 11-06-2012, 12:08 PM
kilapapipa's Avatar
If you put 285 75 r16 on the factory rim it will be around 33" compared to the factory 31" but will not wear correctly due to needing a wider rim. You are also around 11" wide putting more rubber on the road lowering mileage. This is my opinion from experience.
If you just want more height, go to a 255 85 r16. It will still be 33" high and will only be around 10" wide instead of 11" on a 285 75. It will also wear correctly on the rim. This will keep less rubber on the road keeping mileage up and give you more height to fill the cavity as well as gear it higher to help mileage.
REBORN 20 Over on 3/2/11- Pics in my gallery- 2000 F250, Auto, GTP38r, Casserly 238cc/100%, Joey modded 17* hpop, DP F5,HI,60,80E,120R,140A, , Studs and 910's with DI push rods, ARI TC, JW VB, Walbro 392, TC Lock Up, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog 150, SS cover, 6.0 TOC,4" straigt piped and guages, 6637.
kilapapipa is offline
post #7 of 41 Old 11-06-2012, 12:30 PM Thread Starter
irishluck's Avatar
The height is what I'm wanting. But just a little bit.
So you said a 255 85 r16
Since the ones I have now are a 265 75 r 16 can I keep the 265 and just see if I can find a 85r16
post #8 of 41 Old 11-06-2012, 12:40 PM
06_Whitebull's Avatar
Question
I don't think you can get an aspect ratio higher than 75 without sacrificing width. I am looking at tires for myself and took the liberty of running some different sizes for you.
Tire Sizing032.pdf
06_Whitebull is offline
post #9 of 41 Old 11-06-2012, 02:05 PM Thread Starter
irishluck's Avatar
Attachment 45333
would it hurt it to put a 285 on that stock rim?
post #10 of 41 Old 11-06-2012, 02:07 PM Thread Starter
irishluck's Avatar
I think im just going to have to go with whats on my rims.
Id like to get some bigger tires, but there doesn't seem to be what I want.
