Old 10-24-2007, 06:04 PM
Mykol Mykol is offline
What axle do I have?
I emailed an off-road truck parts supply company in regard to pricing information for a limited slip Detroit Truetrac for the rear of my 99.5 F350 dually with 4.10 gears. A rep promptly responded "What axle do you have?". What is he asking?? Thanks
Old 10-24-2007, 06:11 PM
HeavyHauler HeavyHauler is offline
She's paid for!!!!!!
They need to know the size & manufacturer of the axle. I know one way to tell is to count to bolts around the diff cover, but as far as measuring I can't remember how to do it. I'm sure someone will be able to tell you. BTW GIG 'EM!!!
Old 10-24-2007, 06:12 PM
westcoaststrokin westcoaststrokin is offline
Go Navy! Beat Army!
Maybe asking DANA 60, 80 ETC. Just a guess.
Old 10-24-2007, 06:17 PM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
his DRW should be a dana 80.... youll love the detroit tru trac.... ive sold a few of them with great feedback
Old 10-28-2007, 05:34 AM
psychomoto psychomoto is offline
you certainly have a dana 80 with likely a 4.10 limited slip
Old 10-28-2007, 06:22 AM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
you need to look on your door sticker for the axle code...
should match one of these...
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Old 10-28-2007, 11:34 AM
OkieFordFan OkieFordFan is offline
Anyone know what axle code 4N is? Thanks!
Old 12-26-2008, 06:54 PM
Tacomarunner Tacomarunner is offline
Where would I look to know what the front axle is?
Old 12-26-2008, 07:59 PM
NYMustang50 NYMustang50 is offline
There should be tags on one of the axle housing bolts just take a look at it and it should say what it is and what ring and pinion is inside as well.
Old 12-26-2008, 08:05 PM
firemedic355 firemedic355 is offline
Blowin Smoke
Isn't it possible he may have the Sterling axle in there as well? That's what my early 99 Duelly had. I'd identify the diff cover to be on the safe side.
