Old 10-24-2007, 10:59 AM
tubular031 tubular031 is offline
Diesel clean or other additives
Do you guys run that stuff? Or is it called diesel kleen? Should I put some in my truck? Who knows if my tank has a bunch of sludge in it already... If this stuff breaks it free the fuel filter should catch it and my injectors should be ok right? I am paranoid now since this truck has been a slight headach since I got it.....
Old 10-24-2007, 11:06 AM
Lonno Lonno is offline
Huntin Beers in da barrel
I run lucas but a lot of guys here run Diesel Kleen. It's supposed to help lube and clean the injectors.
bigcountrysg bigcountrysg is offline
repairs can't be made
Diesel Kleen is good. I used it before, but I now use a mix of bio con and lucas fuel additive. The Bio Con prevents algae from growing in the tank. The Lucas is similar to diesel kleen. I was using diesel kleen because of how easy it is to get. Every where sells it. Walmart, any auto parts store sells diesel kleen. But I still ended up with algae and other gunk clogging up my pick up tube in my tank. That is why I switched to the bio con and lucas fuel treatment.
Old 10-24-2007, 11:13 AM
I am going to assume that my truck never had anything ran in it. I have 160k on it now. will putting some in the tank hurt anything?
Old 10-24-2007, 11:16 AM
Dirk Dirk is online now
Where can you get bio con? Is it made by CRC?
Old 10-24-2007, 11:17 AM
No but if you have crap built up inside the tank. Be prepared to be changing fuelfilters and possibilly dropping the tank and cleaning it out. As well as cleaning the fuel screens in the pick up tube.
I get it at napa autoparts. I believe it is made by CRC.
Old 10-24-2007, 11:19 AM
awesome. thanks
Old 10-24-2007, 11:20 AM
Any way to tell other then taking the tank off and looking? probably not, but hey ill ask!
awesome. thanks
No problem I also get Lucas at Napa as well. I buy them at the same time. I put the bio con, then I put the lucas in at the same time.
