99 ford lifted rear question(pic)
Ok, I have posted this same question and found out I have a leveling kit on the front of my 99 psd. Here is two pictures of the rear springs. What do I have on there. Looks like a 4" spacer. I dont have any stock pictures to go by so Im searching and asking the people who know. Can I take the 4" block out without messing anything up? Thanks to all. I want to get the truck back to stock or at least lowered some. I bought it to pull a heavy trailer and need it lowered. Thanks.
looks stock to me... the larger block anyway, is that a smaller block below, about an inch think? Stacking blocks is a no-no, but the larger one is factory, you can tell by the bump stop 'arm' sticking out the side. I'll have to look at my early '99 F250 tomorrow in the daylight and let you know if mine looks the same, I'd be it does.
I believe the bottom block is welded on. It looks like a factory weld too. I sure would like some pictures of a stock suspension on a 99. This truck has 4-99 on the door tag. Thanks for the reply.
I'll see what I can do tomorrow for ya... camera is in the truck, and I'm in for the night now.
looks stock to me is it an F250 or 350
I'm not trying to hijack your thread but im interested in what the stock rear axle setup looks like for a 350. I have like 4-6inchs of blocks and 11 springs cause my truck used to have a big utility bed on it... its like riding a iron horse through town.
Mine is a F250 for sure. Thanks for the help.
Stock is like 5 springs in back I think. F-250s have 2.5" blocks, F-350s have 4" blocks. You have a F-350 block in there. The springs look stock.
Here's what I got:
Rear springs of my early '99 F250, stock: ![]() Rear spring of my 2000 F350 DRW, stock: ![]() In reply to your other thread about front springs, heres the front of my early '99 with added leaf, I added the bottom one of the 3 pictured: ![]() Hope this helps you figure out what you have... |
