Synthetic Oil Worth it? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-30-2012, 05:59 PM Thread Starter
Just purchased my dream truck! 2002 F250 Crew Cab with (of course) the best diesel ever put in a Ford truck. It has arouind 240,000 miles on it and runs like new. I've only been wanting one for about 10 years or so...... Anyway, I'm used to running Synthetic oil in my F150 (5.4) and not being as familiar with diesels, I wanted to know what some of you thought about the value of running a synthetic in the 7.3. My buddy runs Rotella in his 01'. Any help would be appreciated.
mikeinorbit is offline
post #2 of 9 Old 10-30-2012, 06:15 PM
rascal's Avatar
Welcome and congrats! Just to forewarn, you are going to get a lot of replys stating you should search for this since it has been discussed a thousand times and/or just pick one you like and go with it.
However, since I basically asked the same question when I was new I will gladly answer. I did a lot of research and decided on Amsoil 15W-40 pre-2007 (emissions) oil since this is the formulation our trucks were designed to use a decade ago. However, this is just my opinion and it is what I like to use. Also, if you get the prefered membership on the Amsoil website the stuff is not as expensive as say Royal Purple and I can also pick it up near where I work so I don't pay shipping.
Good luck!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #3 of 9 Old 10-30-2012, 06:39 PM
SS4Matt's Avatar
depends on where you live if it gets pretty cold or not, I'm in south east michigan, not far from Detroit. In the winter months I noticed a day and night difference from switching from Rotella 15-40 to their synthetic (I think it's 5-40, i forget) but the dark blue gallon jugs, it made my truck start much better in the bitter cold. for that reason alone I run sythetic
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #4 of 9 Old 10-30-2012, 08:31 PM
AOx4's Avatar
I am an Amsoil dealer, so I am a little biased, but even before I sold the black gold I was a fan of synthetic oil. I can go on and on about reasons why, but rest assured your truck will thank you.
Now thats not to say a conventional oil from a quality base is not also good, but a synthetic oil will be even better; plus you get the option of extending your oil change intervals. This saves you money in the long run, even after you pony up for the initial premium for the synthetic.
Regardless of the brand you choose, make sure its a QUALITY oil, no Walmart brands.
Feel free to PM me with specific questions like wanting literature, links, threads, etc etc. I have a library of material on the topic.
- Trey
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, OEM Black CPS, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
AOx4 is offline
post #5 of 9 Old 10-31-2012, 05:09 AM
chrispaine's Avatar
I change my Dino oil every 3-4000 miles and it still drains nice and and clean. I use syn blend rotella 10w40 in winter and If I get any build up I bet it helps in cleaning it out.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #6 of 9 Old 10-31-2012, 05:15 AM
kclough's Avatar
So if you can extend your oil change with synthetic oil, what is suggested mileage on intervals you can go
kclough is offline
post #7 of 9 Old 10-31-2012, 07:23 AM
chrispaine's Avatar
Most will tell you to send in an oil sample to a place like blackstone and they will let you know the condition of your oil and recommend a change interval.
Considering the fuel system of the powerstrokes and oil fired injectors I personally like the idea of the cheaper dino oil that it came with from the factor and short change intervals.
I have heard stories of people going close to a million miles on a 7.3L with the short OCI's.... Regular oil seems to work. I would rather have cheaper rotella,change it at 4000miles and have it come out clean then have expensive syn oil changed at 8000 and come out black as tar.
In my mind clean looking oil is better but oil samples don't lie either, black oil isn't always ready to change.
Also IMO the whole can't go back to Dino oil from syn is bull turd. I like the idea of running a syn blend or full syn every few oil changes (with a good filter) to clean things up.
On the way--
post #8 of 9 Old 10-31-2012, 03:17 PM
Redlazer's Avatar
Synthetic oil is my peference. I agree worth shorter Ico. I run syn rotelia for 7 k.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #9 of 9 Old 10-31-2012, 03:54 PM
Tj Krawler's Avatar
Synthetic. We run Amsoil in everything. Not sure what was in my truck when I bought it, but it started much better with Amsoil. I use 15W-40 "Heavy Duty Diesel and Marine". (PRE 07) IIRC DPF trucks use the "Premium" oil. Beyond that, I don't know what the difference is between them.
I'm getting an analysis at 5k and I'll decide how long to run it from there. I don't think I will go past 10k without changing it.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
