Old 10-23-2007, 09:19 PM
redoil redoil is offline
Home Fuel Oil?
I have a diesel Kubota (as well as a 7.3 PSD Truck). Will I hurt the engine if I use home fuel oil?
Old 10-23-2007, 09:30 PM
alfajay alfajay is offline
Nope, I have done it before but they started having alot of DOT check points around here and I didn't want to chance it.
Old 10-23-2007, 09:38 PM
yamaharider103 yamaharider103 is offline
wont hurt the motor....but it will hurt the pocket if you get cought on the road with it......
Old 10-24-2007, 06:39 AM
95BLKLSC 95BLKLSC is offline
Home heating fuel is colored? I thought it was only off road diesel that was.
Old 10-24-2007, 06:47 AM
WILLIAM LORCH WILLIAM LORCH is offline
Send a message via MSN to WILLIAM LORCH
Info 4u: A Diesel & A Turbine engine will run on chord wood if you could get it chopped fine enough... Remeber Rudi Diesel built this engine to run on veggi oil its origion was to give power to the small shop owner and boats.... Now ome oil would work great in it i would use it if i coulf get my hands on some.. I believe home heeting oil was once caled #1 fuel oil or diesel without additives
Old 10-24-2007, 06:54 AM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Old 10-24-2007, 07:05 AM
PSDfan99 PSDfan99 is offline
It will run, but you will be kicking yourself in the rear if you get caught, that I promise you. Ka-ching! Fines are stiff.
Old 10-24-2007, 07:26 AM
rookie_j rookie_j is offline
correct me if i'm wrong; home heating oil is the same as #2 diesel except for the dye.
the kubota, i assume is a tractor, can use untaxed fuel.
the truck, don't get caught.
