steering box o-rings - Ford Powerstroke Diesel Forum
Old 10-26-2012, 03:50 PM
i have an '03 that i replaced the steering box on about a year ago. it was a cheap rebuilt steering box that came with new o-rings for the power steering lines. i debated on using the new rings at the time and now one of them is blown.
i called the ford dealer and they say it should have some kind of teflon ring? he said they carry these but don't carry any kind of rubber o-rings, just complete lines that would have the rings on them.
after some searching, it looks like the newer ones came with teflon seals... is it a different design of fitting? would i be able to use these teflon ones instead of rubber o-rings?
if not, i'm just going to have to search for some generic o-rings that will work.
Old 10-26-2012, 04:24 PM
i think i just figured it out, some of them use this style of fitting
mine is a flared fitting that doesn't seal up around the threads. the nut holds pressure on the flared fitting.
is it just a rubber o-ring? or is supposed to be teflon o-ring?
