blower motor not working.
First back story. Truck is fairly new to me. Runs good. Shifts good, etc. It started to have problems starting in morning. Exhaust fills with white smoke, bit eventually starts. Used to make it so blower motor would not work untill it warmed up. Now it does.t work at all. Replaced blower motor relay. Still nothing. Any ideas? Would like to start with cheapest, easiest thongs first. Also wondering what hard start and blower motor have to do with each other?
I had to replace the blower motor on my 99 work truck. For a long time it would quit working occasionally. Finally it quit working altogether. After I put the new one on, I saw on the old one that the brushes were wore right down. Mystery solved.
Ya. I hope that's not issue. With it working when it was warmed up leads me to believe is something else I hope.
Check the switch. I had mine not work on med high for a long time. I replaced the resistor and nothing. So I pulled the switch and checked inside of it. It was just dirty, cleaned it and now work great. Don't know if that's your problem, good luck!
it might now work because you do not know how to use it. Stop trolling threads
That makes absolutely no sense. What are you talking about? Are you dense?
