Old 10-23-2007, 09:19 AM
lords88 lords88 is offline
What Fuel Additives?
What kind of fuel additives do you guys use? I was just wondering if there is any additive that is really stands out for mileage and or power.
Old 10-23-2007, 09:21 AM
ksttac ksttac is offline
Hook em Horns!!!
lots of folks here using stanadyne, supposed to be the best, im going to get some for next fill up, ive tried the motorcraft cetane boost and i liked it, i also tried the Lucas upper cylinder lube, not so fond of it.
Old 10-23-2007, 09:28 AM
Where can I get some Stanadyne, without having to order it online?
Old 10-23-2007, 09:54 AM
bfloyd4445 bfloyd4445 is offline
lucas has a minus rateing for wear and is designed for both gas and d. The ford stuff is good and i us ps which you can get at any napa store. ps tested very good with a plus 14 or something like that and is cheaper than lots of the others. Improves mileage by 2mpg not towing. What ever you decide on make sure it is formulated for diesels only.
Old 10-23-2007, 04:26 PM
Dave Dave is online now
Your Whambulance is here
this will help find out where you can get some stanadune locally
https://portal.stanadyne.com/warrant...ppt_search.cfm
Old 10-23-2007, 04:29 PM
WILLIAM LORCH WILLIAM LORCH is offline
Send a message via MSN to WILLIAM LORCH
I've had good luck with both saydine and Power service I can usualy get Power service at any fuel stop... Bill
Old 10-23-2007, 04:30 PM
sevenmalards sevenmalards is offline
Will training EVER end?
I use RED LINE OIL, TI 85 PLUS it's pretty good.
