loss of power in cold weather? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 10-21-2012, 09:54 PM Thread Starter
My 2000 7.3 loses power in cold weather. whether it be first start up in the morning even after letting it warm up for 10 min. Or driving in the snow. Is there anything wrong with my truck or is that just how 7.3 are? If that is the problem is there a performance part I can buy to help this? Hope anyone can help
randycooper is offline
post #2 of 28 Old 10-21-2012, 10:50 PM
JSchuricht's Avatar
Are you running #1 or #2 diesel?
JSchuricht is offline
post #3 of 28 Old 10-21-2012, 11:25 PM Thread Starter
Idk what is the difference?
post #4 of 28 Old 10-22-2012, 12:31 AM
BIG Laing's Avatar
I would add a fuel additive anti gelling to a few tanks. If it works great, if not your only out $10.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 28 Old 10-22-2012, 03:18 AM
Zaairman's Avatar
Quoted: 12 Post(s)
And I'm guessing it sounds funny and you only drive it for 20 mins, right?
It's your EBPV. Totally normal for cold weather. It will shut off when the motor is fully warmed up.
Winter Operation, Hard Starting, Hissing Sound Etc...
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #6 of 28 Old 10-22-2012, 05:40 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
These trucks do not like to 'start up and go' when it's cold out... like Zaairman said, the EPBV comes into play when cold starts occure, and will continue to effect performance untill the motor warms up, and even after, if it's cold enough.
I normmally plug them in at anything below 30-35 degrees, not because the glow plugs don't work, but because I think it's better for the motor to be warmed up for start up, less wear and tear on berrings and such if it's that much closer to operating temp to begin with, as well as I like to have heat almost instantly! Sure, with a properly operating glow plug system they will start at or below 0 degrees F, but it's just so much easier on the whole system when it's warmed by having the block heater pluged in.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #7 of 28 Old 10-22-2012, 05:42 AM
Jrz13's Avatar
You could run a cranking vacuum test and compression test to try to determine if your prob is in the engine or secondary systems. If it were my truck, thats where Id start
Forged Rods
ARP Head & Main Studs
Port, Polish, 3 way valve job
Beans 160cc Single Shot Injectors
DI Regulated Return/Oil X Over
DieselSite Coolant Filter
TS 6 position (Beans Tunes)
AFE stage 2 dry
Labonte Stage 3 Methanol Injection
Banks wheels, exhaust housing, wastegate, Intercooler
5in Turbo back Exhaust
Custom Built Trans w/ Billet Shafts
Mag-Hytec Trans Pan/Diff Covers
6.0 Trans Cooler
SnowDogg EX90 plow
Jrz13 is offline
post #8 of 28 Old 10-22-2012, 07:28 AM
Its the ebpv. And NO diesel likes the cold. They are all picky.
85_305 is offline
post #9 of 28 Old 10-22-2012, 07:50 PM
'01SilverBullet's Avatar
Quoted: 4 Post(s)
Don't forget about winter blend fuel...we're coming upon that time of year out in the Midwest.
EBPV will also cause poor performance when it's closed...it's basically a glorified exhaust brake designed to help warm the engine, via load...and it's annoying as hell.
2001 F250, 7.3, Automatic, 4x4, 33's, Leveled, Cobra 29 CB Radio, Single Firestick anteanna, Pioneer Head Unit, Riffraff 6637 Intake Kit, 4" turbo-back straight pipe, Dual Alternator Upper Radiator Hose, AutoMeter Boost, Pyro, Trans Temp, CM RD Flatbed with Gooseneck and Rear Hitches...and a heavy right footed driver...
Wishlist: 160cc single shots, GT38r, BTS, SRP 1.1
REAL TRUCKS DON'T NEED SPARKPLUGS!!
Lord, please take care of this drivin' fool...
'01SilverBullet is offline
post #10 of 28 Old 10-22-2012, 08:26 PM Thread Starter
The coldest it gets where I live is about 25 degrees and I've never heard of a winter blend? Is the ebpv that hissing noise out the exhaust when my truck is warming up then shuts off?
