Old 10-22-2007, 06:37 PM
rubbernecker rubbernecker is offline
Forum Is A Life Saver
Just discovered and joined forum today. Already saved myself a trip to the Ford dealership and at least a couple of hundred bucks. Was having trouble with not being able to get the auto trans to shift into park on my 2000 F250 7.3. Could not start engine without placing shift lever to neutral. After searching forum for info, found comments about possible adj where cable to trans is attached to the steering column. Upon investigation did not find adjust for cable there but did discover that the star head bolts which attach the cable assemble to the steering column were begining to loosen. After retightening the bolts trans can be shifted to park and the engine can be started in the park position. Thanks forum for at least pointing me in the right direction and saving me several hundred bucks I'm sure.
Rubbernecker In Arkansas
Old 10-22-2007, 06:41 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
Glad you got it fixed!
Welcome to the ORG.!
Old 10-22-2007, 06:42 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Awesome bud! Glad the forum helped get you fixed up! That is the reason I joined this place, and now I'm addicted
I'm not too far away from you -- located in North Central, Oklahoma. Went to Eureaka Springs last year -- beautiful country in that part of AR!
Old 10-22-2007, 06:44 PM
Logan Logan is offline
The Fat Mod
Glad you got it fixed up and it doing better. :elcome1: to the ORG.
westcoaststrokin westcoaststrokin is online now
to the ORG!!
Old 10-22-2007, 06:48 PM
dikdragon dikdragon is offline
Old 10-23-2007, 02:13 AM
Big AL Big AL is offline
Strokin' In Dixie-Land
Welcome to the Site! Glad you got your problem eliminated.
Old 10-23-2007, 02:15 AM
DKR DKR is offline
<--Pro Cooler Racer
Nice work and to the ORG!!!
Old 10-23-2007, 02:29 AM
Dave Dave is online now
Your Whambulance is here
Welcome to the site man
Old 10-23-2007, 03:16 AM
Rodslinger Rodslinger is offline
Gun Nut
WELCOME!! Great to have you and glad the site was able to help you out.
