towing capacities
I can't seem to find why tow capacities went up in 2002. I'm going to be purchasing a 2001 excursion next week. I will be using it to tow a travel trailer approximately 9,000lbs. Will the excursion pull the trailer just fine? Should I hold off for a 2002 or newer?
Thanks |
Yeah it will pull it just fine. I've pulled close to 26k with a short bed 250 which is basically the same thing as an excursion. Might want to invest in some air springs though. Helps with the sag.
Hiller Ford - Ford Trailer Towing Guides
2001 excursion 4wd page 22 shows 10,000lbs max 2002 excursion 4wd page 22 shows 11,000lbs max I was just wondering if anyone knew what was done to give it an extra 1,000lbs? |
Most tow ratings are based on warranty they really don't hold validity as to the capability of the truck if that where the case a bunch of folks would have a busted truck specifically a bunch boys who run cattle
Sent from my iPhone using Autoguide |
Ok. I saw somewhere a guy say he would only buy an 02' or 03' because of the tow rating. Thanks all for the info!
I am betting the reason is because in 2002 they upped the power ratings on the 7.3, but really ratings are a guideline.
^Yes I bet it has to do with the upped power ratings.
So nothing to worry about, I should be fine pulling that weight.
Dude... you will never put something behind that truck heavy enough to "worry about the weight". I know guys pulling 20-30k lbs in hay and farm/construction equipment with these trucks stock.
Only thing that gets hair is braking and handling the curves at that weight. |
