Help with 7.3 - Ford Powerstroke Diesel Forum
Old 10-17-2012, 01:52 AM
Help with 7.3
Intermittent shut down of one bank.Have changed UVCH.
What else can cause this?
See my other post.
Old 10-17-2012, 01:55 AM
Previous post 2004 7.3 in Australia help please
Old 10-17-2012, 07:17 AM
Where did you get uvch from? is it a known-good harness?
Old 10-17-2012, 10:42 AM
Brand new.IDM?
Old 10-17-2012, 10:51 AM
I really dont think IDM. NO codes at ALL???????
Old 10-17-2012, 11:06 AM
Yes the only code i could get was the 1316.
Gaskets and harness new.Does not do it all the time.
Old 10-17-2012, 11:09 AM
It MIGHT be an IDM code dude.. its just not adding up. Make sure ALL injectors are plugged in and firing. Make sure that ALL the harnesses are tight and not crimped off... try start w/ the vc off and see what happens. But as a last resort I'm wondering if that IDM is actually toasted......
What are you using to pull those codes? It sounds like you aren't using a good scanner and you need to get ahold of a good one.
