No pulling power - Ford Powerstroke Diesel Forum
Old 10-14-2012, 02:46 PM
No pulling power
Yesterday I noticed my truck was noisier than usaual I didn't think anything of it I hooked up my gooseneck and away I went the first hill I got to I had no power the truck started to vibrate real bad and slowed down to about 10 mph it started to run like it was out of fuel but its not alot of stuttering. 2003 7.3 with power hungry tunes dieselsite cpr bts valve body and a new ford trans. Iam thinking turbo or injector
Old 10-14-2012, 02:52 PM
Need to check fuel pressure, ICP, boost, and do a couple cylinder tests.
Old 10-14-2012, 02:59 PM
Boost feel off to like 10 lbs and when I got home I took thevtruck for ride with no trailer on my highest tune which normally shows 24.7 lbs of boost fuel pressure is between 65/70
Old 10-14-2012, 03:20 PM
So was the boost low with trailer on and off? Any smoke out of tail pipe?
Old 10-14-2012, 03:24 PM
The boost was really low the trailer and with the trailer under extreme conditions up hill say real low boost vibrating I thought the truck was going to stall out without the trailer you can drive the truck all around the injectors soundvreal loud and when go WOT it feels like it way down on power and boost is low but not as bad
Old 10-14-2012, 03:38 PM
Ok well there may still be another issue causing the low boost.
Old 10-14-2012, 03:44 PM
I am listening I'm looking for some direction this all of a sudden happened but I have noticed that lately it has been noisier then normal on clod starts it has no power until things warm up it seems but this major issue happened yesterday
Old 10-14-2012, 03:45 PM
Do you think injector problem
Old 10-14-2012, 03:46 PM
I listed what I would check first.
Boost, ICP, fuel pressure, cylinder buzz and contribution tests, even MAP and EBPS readings.
Old 10-14-2012, 04:06 PM
Do you still have the EBPV on there still?
