Boost leak - Ford Powerstroke Diesel Forum
Old 10-12-2012, 07:02 AM
Boost leak
Today I did the DIY 6637 intake and said hell while im here ill do a foil delete. Started cleaning the adheasive off and the pipe(dont know what its actually called) has a dent and crack in it.
Could i use JB weld or aluminium tape as a quick fix untill I can get new one?
Is there any benefit on having aftermarket compaired to stock?
Sent from my ADR6325 using AutoGuide.Com Free App
Old 10-12-2012, 02:19 PM
no benefit to aftermarket intercooler pipes unless you get a diff cooler.
you could try patching it for now. just to get you by
Old 10-15-2012, 06:33 AM
I would try welding it... a lot of pressure goes thru those pipes. Dont be messing around with stuff thats just not gonna work.
Old 10-15-2012, 06:23 PM
There is No psi on that pipe, just slight vacume as its pre trubo. Id clean it and JB weld it smooth and paint it. The shape looks like a cone theres no way it could ever be sucked into the trubo.
Just my
goodluck
Old 10-15-2012, 06:53 PM
Just my
goodluck
That tube is NOT pre-turbo. its the hot-side cac tube after turbo. If his truck builds 20psi, that spot will see 20psi.
The hole was made from the banjo fitting on the power steering unit / resivoir. Like 305 said, get it welded then put some type of foam padding glued in that area so this problem dont happen again.
Old 10-15-2012, 10:08 PM
Thanks guys I guess ill weld it. I priced a new one at the ford dealership 125 bucks. Id much rather save that so i can get gauges and tunes sooner.
Old 10-16-2012, 04:47 AM
Just my
goodluck
Umm... intercooler piping is what carries the boost....
Good idea. No need for a new one. Just a tack weld will probably do.
Old 10-22-2012, 09:47 AM
lol I gotta quit drinking haha..idk why I was thinking the intake pipe, maybe because thats where mine had rubbed a hole. well theres my newby woops
Old 10-22-2012, 10:17 AM
Off topic, I know, but can anyone tell me why you would want to do the foil delete?
Old 10-22-2012, 10:19 AM
Because it lets the turbo sing like a mofo
